NOOB ECU Compatibility Question
I fried my ecu from getting a "ton" of water on the passenger floor. Are all the ecu's compatible? I have a 96 Accord 2.2l non vtech, auto trans. Current ecu 37820-P0J-A80
Also, I'm assuming it's the ECU. There was a lot of water on the floor. Prior to that the car was running okay. I did a tune up, cap, rotor, wires, plugs, thermostat. After sitting overnight(after the water spill) it wont start again. It cranks nice, fuel pump relay clicks(twice) and the fuel pump can be heard.
Is the ECU still wet? It's pretty easy to take it out of the car, open the case, and let it dry out if it's still wet.
A sedan/coupe ECU can be used with a minor external wiring modification. This page has a table that shows compatible ECU part numbers:
This page shows the mod:
Without the mod a wagon will run fine on a sedan/coupe ECU but it will throw a CEL.
pennybaker(dot)com/ody/sb/SB%2001-012(dot)pdf
accordwagonclub(dot)com/forum/viewtopic(dot)php?f=84&t=11876&p=97492&hilit=pot#p 97492
Its not the fuel pump relay. I bought a new one and that didn't solve the issue. On the fuel rail, when I loosen the small nut/valve on top at the drivers side should there be a bunch of pressure?
