NOOB ECU Compatibility Question
Old Feb 24, 2014 | 11:44 AM
Roader's Avatar
OK. I was thrown when you wrote "I fried my ecu." It seems like now the ECU may not be the culprit? From experience, loosening the fuel line banjo bolt results in a short but big spray of gas.
Spark/fuel/compression. Pull a plug wire off, stick an old sparkplug into it, lay it on the valve cover, crank the engine. Nice blue/white spark? Pull the hose off of the throttle body and spray starter fluid into the throttle body while a helper is holding the gas pedal halfway down and cranking the engine.
Old Feb 24, 2014 | 12:48 PM
JayKranz's Avatar
Its not the icm/igniter that tested good
Old Feb 24, 2014 | 12:50 PM
JayKranz's Avatar
I have spark and the starter fluid didn't do it. When I pull the banjo off the gas just sort of gently flows out. Not huge pressure or anything.
Old Feb 24, 2014 | 01:27 PM
JayKranz's Avatar
I just pulled the plugs again and tested for spark, all four cylinders are getting spark, also there was fuel on all four plugs. It seems like it wants to start but no luck.
Old Feb 24, 2014 | 01:31 PM
JayKranz's Avatar
What if the spark is just weak, would that keep it from starting?
Old Feb 24, 2014 | 01:34 PM
JayKranz's Avatar
Also now the D4 light comes on when turning the key and it didn't before.
Old Feb 24, 2014 | 01:38 PM
  #17
Roader's Avatar
What color is the spark?
Old Feb 24, 2014 | 01:39 PM
  #18
JayKranz's Avatar
looks white to me
Old Feb 24, 2014 | 01:41 PM
  #19
JayKranz's Avatar
Also still no check engine light or anything
Old Feb 24, 2014 | 01:55 PM
  #20
JayKranz's Avatar
D4 light turns off after about two seconds
