noob question
Old Oct 13, 2007 | 03:02 AM
Creepy Tony
Default noob question
i have a honda accord 2000 and my ac adapter and radio arent workign i know itsa fuse basically can someone tell me which one cause its not specific on the pannel, pleas ehelp
Old Oct 14, 2007 | 01:30 AM
00AccordLX5spd's Avatar
Registered User
Default RE: noob question
4cyl or v6? 4 door or 2 door? Auto or Manual trans? Put that info in your signature like mine below.
As far as your question goes, I do not know. If I were you I would just start checking all the fuses and replace whichever is burned.
Old Oct 14, 2007 | 02:05 AM
smaglik's Avatar
ac adapter?
Old Oct 14, 2007 | 11:30 AM
nafango2's Avatar
just look at each fuse in both fuse boxes. (theres one by the pedals and one under the hood. check both.
Theres a little tool called a fuse puller in the fuse box by the pedals. If you cant see All the filaments in the fuses, try pulling the ones you cant see then put it back in.
You can tell if its burned out if the little wire that goes across the middle of the fuse is not longer connected (it looks melted)
iimzii85
Jun 29, 2010 09:44 AM
mrbaysick
Oct 1, 2008 04:43 AM
vtecluder617
Jun 2, 2008 10:51 AM
WeeAsp
Jul 31, 2007 07:17 PM
07AccordCPE
Mar 13, 2007 09:09 AM
