OBD access?
Old Jul 7, 2008 | 04:08 PM
Erinsaccord's Avatar
Default OBD access?
94 Accord LX withcheck engine lightthat just came on. I would like to pull the codes but can't find the plug. Any help with where I can find it? BTW, the car runs fine.
Thanks, Dave
Old Jul 7, 2008 | 04:39 PM
Default RE: OBD access?
http://www.dhost.info/accordinfo/
Just open CEL code retrieval link. It has pictures to help. Use a paperclip to jump the connector.
You can also download the shop manual from the bottom of that site. Each chapter is a seperate pdf file.
Old Jul 7, 2008 | 05:06 PM
ford's Avatar
yeah just as PAhonda said..go to that link and there should be an instruction on how to retrieve the code from the CEL...
btw..you will need a wire (jumper)/ or you can use a small paper clip... the OBD plug is on the front passenger side..its behind the the glove box...
Old Jul 7, 2008 | 08:39 PM
Thanks, guys. I'll try this out and be back in touch.
sooty305
Jul 6, 2012 07:14 PM
dragonle87
Oct 5, 2009 09:53 AM
dragonle87
Oct 4, 2009 08:54 PM
tcodi
Aug 12, 2006 11:33 AM
acalder
Jun 30, 2006 07:19 PM
