OBD-I engine in OBD-II car
Old Jul 6, 2012 | 06:00 PM
sooty305's Avatar
Default OBD-I engine in OBD-II car
I have a question and im trying to get reassured because i plan on doing some mods in the future but im not sure about the mod i have to do right now.
I have a 1996 CD7 2 door accord ex 5-speed with a stock F22B1, my car is OBD-II, I have a problem right now where exhaust is seeping into my radiator so im pretty sure my HG is gone, so i have sourced another F22B1 from a local shop for $200 but it is OBD-I so i have not jumped on it yet. My question is can i put the OBD-I engine in my accord with out having to modify anything? from what i have read online the F22B1 motors are identical even tho some are OBD-II and some are OBD-I, the other F22 engines are another story. If i do have to change my car to OBD-I can i use the engine harness from the plug on the strut tower to the engine from a 94-95 accord, and use and OBD-II to OBD-I harness @ the ECU?
Old Jul 6, 2012 | 06:23 PM
Are you swapping the engine or just the cylinder heads?
Old Jul 6, 2012 | 06:38 PM
sooty305's Avatar
i was planing on swapping the whole engine, my car still runs but it overheats so i have to go easy on it and i know driving it is not good for the engine. if i where to swap just the head i might as well just try to replace the head gasket , the thing is i dont know what kind of condition the head is in, if i pull it and the head is cracked im stuck. I was planing on buying a new head gasket, water pump, timing belt, crank and cam seals, and both tensioners, but if the head is cracked those parts are not going to help. so i figured 200 in parts or 200 in a spare engine and the engine feels like a safer bet.
Old Jul 6, 2012 | 06:42 PM
Silver6gen's Avatar
besides the issues of having to completely rewire your car, i think it would junk the title. I think and im not sure about this but i think there is a legal issue involved too. Also how do you know it will only cost 400? are you sure the new engine doesnt have a blown head gasket or other issues?? I think you'd be better off just fixing the head gasket.
Old Jul 6, 2012 | 06:49 PM
sooty305's Avatar
what do you mean by 400? im either spending 200 for a water pump, head gasket, timing belt, tensioners, and seals, OR 200 for a complete running engine, which he compression tested in front of me, and seems to be fine. I guess i could pull the head off and look at how bad it is before i do anything. also what do you mean legal issues? I live in florida we dont have smog inspections so i shouldnt have any issues with a swap or converting to OBD-I
Old Jul 6, 2012 | 06:53 PM
The 94/95 OBD1 engines are almost identical to the 96/97 OBD2 engines.
The one difference is that two sensors in the distributor of the 94/95 were moved to under the timing cover on the 96/97 engines.
I would suggest using your stock wiring.
The two sensors under the timing belt cover, the oil pump/housing, and the crankshaft gears under the timing belt cover on your accord will have to be moved to the 94/95 engine.
Old Jul 6, 2012 | 06:55 PM
sooty305's Avatar
so i would need to swap over my stock Oil pump with its housing, the crankshaft gear behind the pulley, and two sensors. Which 2 sensors would that be? by the parts your telling me im guessing some kind of angle sensors.
Old Jul 6, 2012 | 07:00 PM
sooty305's Avatar
wait a minute i just thought of something, ( massive brain fart ) cant i just use my obd2 distributor?
Old Jul 6, 2012 | 07:14 PM
No, because your OBD2 distributor has only one sensor (cylinder position sensor).
You would still need the crank angle sensor and the top dead center sensors from your original motor.
I think the OBD2 setup is better, because the crank and tdc sensors are actually reading the lower half of the engine.
If the replacement engine is getting a timing belt replaced, then swapping the oil pump housing is one extra step.
Crocen
Dec 27, 2012 09:47 PM
dragonle87
Oct 5, 2009 09:53 AM
dragonle87
Oct 4, 2009 08:54 PM
sir_nasty
Mar 17, 2006 01:50 PM
marbro
Mar 8, 2006 08:47 AM
