Odd electrical issue on 95 Accord
Old Nov 30, 2006 | 02:19 PM
mooretimothya
Default Odd electrical issue on 95 Accord
Hello,
I've been searching the internet for days trying to get to help with an issue I'm having with my 1995 accord LX-V6...no luck so far.
I hope you guys can help.
The car runs/drives great, but i'm having an electrical issue that is ruining the car's drivability.
At random, usually at start-up, the instrument panel will not work. No gauges work. The blinkers work though.
Also, at the same time that the gauges quit, I've had to use the 'shiftlock release' button to shift from P.
The windows/sun roof also quit when this happens. The radio works though.
This has happened 3 times now. 2 times everything came back on at random while driving, only to act up again next time I started the car.
Any Ideas?
Thanks!
Tim
Old Dec 1, 2006 | 01:46 PM
mooretimothya
Default RE: Odd electrical issue on 95 Accord
Problem Solved! After digging around the forum, I found a thread that suggested checking/replacing the #1 underdash fuse. That was the problem. The fuse was blown. It looked a bit different from other blown fuses I've seen, but it was blown none the less.
Tim
Old Dec 2, 2006 | 09:50 PM
mamarotta's Avatar
i had somehting similar it was the battery same dash freakyness. batteries are bad in 2 ways 1. wont hold charge or when it becomes a break in circuit...meaning its an open.. thats when ur dash board flickers.. by the way thats the same symptom that a bad alternator.
Old Dec 3, 2006 | 12:17 PM
deserthonda's Avatar
glad that it is fixed and that you actually did some searching to fix the problem,,,,,,,,,,,,
,,a very good example of what more members should do ,,,,if one is willing to spend some time searching one would be surprised the amount of information one can find in this forum
mgg4591
Apr 12, 2014 08:55 PM
heyfunny
Mar 22, 2012 12:19 AM
wickibet
Nov 10, 2010 12:05 PM
thesameguy
Nov 17, 2009 12:20 PM
j7wb
Sep 12, 2007 02:18 AM
