Odd problem...
Old Jan 24, 2013 | 12:15 PM
94ex915's Avatar
Almost A Senior Member
Originally Posted by JimBlake
If you were talking about the temperature gauge working or not, then I'd say a bad ignition switch could be the problem.
Ya definitely the gas gauge. Now its not starting and the gauge dropped to e again.
Old Jan 24, 2013 | 01:30 PM
94ex915's Avatar
Pulled the main relay but don't really know what to look for. Here is some pics.
Old Jan 24, 2013 | 01:59 PM
94ex915's Avatar
Here is some bigger pics just in case.
Attached Thumbnails Odd problem...-100_1772_zpsf8b271dc.jpg   Odd problem...-hondajpg_zps6ce7d69b.jpg
Old Jan 24, 2013 | 02:45 PM
accord1224's Avatar
how many miles on the car? sounds like your fuel pump is kaput. replace it.
Brian B
Old Jan 24, 2013 | 04:03 PM
94ex915's Avatar
Brian B
Around 130k miles. But the fuel pump would affect the gas gauge?
Old Jan 24, 2013 | 06:46 PM
94ex915's Avatar
Alright so I went in and removed all the carpet and everything from the back. Found a ground that looked disgusting and was a little loose. I'm assuming that this is the ground for the Fuel Sending Unit. So cleaned it up and sanded down the area. But the ground back on and I hear the fuel pump come on when I turn the key and the gas goes back up. So far everything seems to be working normally. Anyone have any thoughts on this?
Old Jan 25, 2013 | 07:28 AM
  #17
Cross your fingers & hope it's fixed. A bad ground can certainly cause both the fuel gauge and fuel pump issues.
Main relay could've caused the fuel pump issues, but not the fuel gauge. Pics are a bit out-of-focus, but you're looking for tiny hairline cracks in any of those solder joints on the circuit board. If you're good with a soldering iron, you could re-melt all of em anyway, just for grins.
Old Jan 25, 2013 | 01:58 PM
  #18
94ex915's Avatar
Ya sorry about the pics. Tried to take the best ones I could lol. But yes I did re solder the joints. 2 of them had cracks. Problem does seem fixed for now and I will keep updated if the problem comes back. Thanks!
Old Jan 28, 2013 | 11:46 AM
  #19
accord1224's Avatar
fuel pumps many times now come as assemblies and in these assemblies are incorporated the fuel level sender.
if you found that it was a loose connection, then you have possibibly found your problem. Yah Yah! I hope this is it, cause it saved money!
an intermitten electrial supply can cause the same symptoms as a fuel pump going bad.
Old Jan 28, 2013 | 02:08 PM
  #20
94ex915's Avatar
The problem hasn't seemed to come back so I'm assuming this was the problem. Saved me a good amount of money
