Odd squeaking sound
Old Nov 3, 2012 | 08:17 AM
drummer1279's Avatar
Default Odd squeaking sound
Hello all, been working a lot and the honda is still my workhorse, but a potential issue is creeping up.
For theast 3 days when driving, if i go to make a turn (left or right) i am getting an occasional squeaking sound, much akin to a like a squeaky door or the like that sounds like some WD-40 would fix. I am at a loss as the car is showing no other signs of anything wrong. PS fluid is full, pump and belt are also both intact.
Old Nov 3, 2012 | 09:14 AM
Check the ball joints. They can cause a noise when turning.
Old Nov 3, 2012 | 09:43 AM
will do. I might add (as I just thought of it) that the sound sounds like it is inside the driver's compartment, and not from the outside. almost like the steering wheel itself has developed a squeak.
Old Nov 3, 2012 | 10:02 AM
Well, that could be....yes I was assuming under the hood.
Noises are hard to describe.....
If it is like a metalic squeak, then I'd be with checking the ball joints.
If it is like a plastic squeak, then the shroud(s) around the steering wheel could cause this.
Again, the difference in the sounds is hard for me to even describe
Old Nov 4, 2012 | 11:43 AM
yeah its odd. I can distinguish between under hood and in cabin noises, and it def. sounds more in the cabin.
Old Nov 8, 2012 | 10:13 AM
ok, an update. the noise is not a constant, but it did make it a few times yesterday. this morning I went to check my oil, and I noticed that my PS reservoir was wet with fluid, not enough to affect the level, but like some had "burped" out of the cap.
Old Nov 8, 2012 | 05:51 PM
Could be there is a blockage or leak in the system that causes the fluid to foam up and out of the res......could the noise be a belt slipping? What did/does the under side of the hood look like....about where the pump and res would be when closed.
Old Nov 11, 2012 | 04:24 PM
its just the res that seems to have any liquid on it, nothing else looks like it has been sprayed. I crawled up under it yesterday, all of the balljoints, steering arms, cv's look intact.
VSW1991
Jun 19, 2011 09:53 PM
RA1525
Jan 13, 2011 08:18 AM
Cineris1104
Sep 7, 2010 03:21 PM
Rob_KCMO
Aug 25, 2010 05:03 PM
davidinaz
Nov 20, 2006 11:14 PM
