Odometer/tripmeter on 96 Accord
Old Oct 11, 2007 | 06:55 AM
trolddk's Avatar
Default Odometer/tripmeter on 96 Accord
Hope you can help me out...
Today the odometer and tripmeter stopped working exactly when the odometer was changing to 137,000 miles on my 1996 Honda Accord. The speedometer still works fine.
Any idea how to fix this and how difficult is it? Any idea how much it would be to have somebody fix it for me?
Thanks!
Old Oct 11, 2007 | 07:41 AM
2POINTautO's Avatar
Default RE: Odometer/tripmeter on 96 Accord
Worst case the entire cluster will need to get changed out, easy to do, you have to decide if a used one is for your pocket book, also your state may require paperwork to prove out the original milage???
I would pull it out and see if there is a cable drive from the speedo motor to drive a mechanical gear setup to the ODO unless someone here already knows better.
Old Oct 11, 2007 | 01:39 PM
smaglik's Avatar
is it stuck? try hittin the dash above it. sounds ghetto, but you never know. mine used to lag when it would flip the big numbers.
Old Oct 11, 2007 | 01:49 PM
falkore24's Avatar
Smag, do you have a little TV that works on top of a wood encased one with a green screen?
Old Oct 11, 2007 | 03:29 PM
smaglik's Avatar
no...i spend money like its water on electronics...i watch on a bravia 32"
seriously though, it never hurts to give it a smack and utter a couple of 4-letter words.
Old Oct 11, 2007 | 03:41 PM
00AccordLX5spd's Avatar
Registered User
Plus it makes you feel better. Even if it doesn't help.
Old Oct 12, 2007 | 07:39 PM
trolddk's Avatar
Smaglik:
Well, I am very thankful - after a few minutes of banging on the dash, it started working again.
Thanks for the help - I can't believe it worked.
Old Oct 14, 2007 | 01:41 AM
Registered User
NICE!!! ROFL!! It just needed some "coaxing"
Old Oct 14, 2007 | 02:03 AM
smaglik's Avatar
wow. that is classic. this should be a DIY.
Old Oct 14, 2007 | 07:06 PM
BRIVOLBN7Q's Avatar
put some graphite in it works like it does in a lock. a little lub.
JustaDD
Feb 9, 2012 11:37 AM
bpIII
Apr 26, 2009 08:28 PM
cooch_csg
Nov 25, 2008 10:04 AM
pfrathjr
Mar 14, 2008 03:50 PM
ibornagain
May 12, 2007 08:51 PM
