Oh no, jerking. Spark plugs have been changed!
Old May 7, 2009 | 06:16 PM
92Accordion
Default Oh no, jerking. Spark plugs have been changed!
Thanks in advance.
Finally upgraded to a Standard Honda Accord 1994 EX. It's been running fine...but as of late I've noticed it's started to jerk around the 50 mph range. When I shift to 5th gear it spasmodically jerks. After I pass up 50 - 55 mph...no more jerking. It just seems that the jerking is confined to that particular area. 50 - 55 mph.
Your thoughts and wisdom are appreciated.
Old May 7, 2009 | 07:11 PM
This could be an EGR lean miss due to partially blocked EGR ports. If you've never removed and cleaned EGR manifold and ports into intake manifold, this maintenance should be performed. It may cure your problem.
Old May 7, 2009 | 09:48 PM
hondadude's Avatar
Try this link below....I think the guy has done a few EGR port cleans in his lifetime.
http://www.freewebs.com/hondadude/95...5AccordEGR.htm
Old May 9, 2009 | 01:16 PM
99accordFX's Avatar
Yeah try unplugging the egr valve and see if it runs better. If it does then you know to clean ports under intake. Doesnt take very long at all.
93Accord2.2
Nov 6, 2013 11:53 PM
d0n
Feb 20, 2013 08:14 PM
sirtwist2
Sep 24, 2012 01:36 AM
DannyJdm
Aug 30, 2012 07:37 PM
felpz420
Jun 24, 2011 12:31 AM
