Oil Consumption
Old Nov 4, 2007 | 08:15 AM
Bosch232's Avatar
Default Oil Consumption
My company car currently has 246,500 miles on it.
It consumes abouta quart of oil every 2,000 miles.
Just checking with the collective knowledge pool to see if this sounds similar to others' experiences.
Old Nov 4, 2007 | 05:01 PM
accord4sroy's Avatar
Default RE: Oil Consumption
Need to know what year and model. Please put that in your signature.
Old Nov 5, 2007 | 05:24 AM
Chiovnidca's Avatar
ORIGINAL: Bosch232
It's nothing to worry about imo. Top off the oil at every fuel fill up.
<edit> make sure there are no leaks.
Old Nov 5, 2007 | 12:33 PM
nafango2's Avatar
yea any vehicle with that many miles is going to burn oil.
Old Nov 5, 2007 | 01:02 PM
falkore24's Avatar
do a compression check. that will tell you if the oil loss is reasonable for the wear on the internals. It sounds fine to me as well.
Old Nov 8, 2007 | 08:34 PM
Bosch232's Avatar
It's a 2001 LX.
About a month ago the compression was checked and was about 175 for each cylinder.
For unknown reasons, cylinder No. 3 is a bit lower at 165-170.
I average about 3700 miles a month in this car, it's 90% hwy miles.
Old Nov 9, 2007 | 08:31 AM
falkore24's Avatar
well .... that's good compression. The #3 cylinder may have a bit of blow-by. Do you have any blueish exhaust?
Old Nov 9, 2007 | 04:34 PM
not in my opinion if you take care of the engine (i.e. oil changes). also, if you replenish all your fluids when you need to then the engine should last a long time.
hondabeat.com
there's some awesome stories there! it gest addicting to read!
Old Nov 9, 2007 | 08:16 PM
nafango2's Avatar
you sure it isnt something thats leaking?
Old Nov 10, 2007 | 12:29 PM
Yeah, I would check if something is leaking. Oil pan gasket comes to mind or some people have stated a rear main seal leaking.
rikee
Mar 10, 2015 09:24 PM
Moddage
Feb 27, 2009 11:39 PM
kris_loehr
Jan 12, 2009 04:23 PM
jerrym
Dec 5, 2008 06:58 PM
axelrod
Dec 14, 2007 05:13 PM
