oil leak
Old May 20, 2011 | 10:00 AM
drummer1279's Avatar
Default oil leak
I am leaking oil somewhere on the bottom end. the concentration is around the crank pulley. my first guess is the front crankshaft oil seal. anything else I should consider?
Old May 20, 2011 | 05:33 PM
JMH's Avatar
JMH
Based on your description of seeing most of the oil around the crankshaft...
There are 3 seals behind the timing belt cover, the crankshaft seal, the balance shaft seal and cam shaft seal. The cam shaft is up high and if leaking would run behind the TB cover and appear low. So, if your sure its not the valve cover gasket, its most likely one of these seals.
If you dig into this, your 75% of the way through a timing belt & water pump replacement job. So might as well replace those also.
Old May 22, 2011 | 11:02 AM
that's the thing, I had timing belt/water pump set change in January. changed all those seals too.
Old May 22, 2011 | 11:32 AM
Well if you're sure the valve cover isn't leaking (at the end by the cover....I don't think there is much else it could be. Pull the upper t-belt cover and take a quick look.
Old May 23, 2011 | 01:40 AM
desertmike1's Avatar
Did you change the "balancer gear case" oring, mine was leaking, and flat as a pancake.
Old May 23, 2011 | 08:21 AM
I bought a kit, timing and balance shaft belts, water pump, tensioners, cam, balance shaft and one other seal I can't remember.
Old May 23, 2011 | 08:29 AM
Old May 23, 2011 | 08:30 AM
so i guess it must be either the valve cover gasket, or oil pan gasket maybe?
Old May 23, 2011 | 03:04 PM
I pulled my valve cover and checked the gasket, it's still soft and pliable, not cracks or breaks. I put it back on and made sure it was tightented down correctly. we'll see if that works.
Old May 23, 2011 | 04:04 PM
Did you put a dab of RTV on the corners where the gasket makes an arc?
