Oil Leak on Passenger Side..HELP!!!!!
Old Aug 12, 2010 | 03:00 PM
Pearl Jammer's Avatar
Default Oil Leak on Passenger Side..HELP!!!!!
My 18 yr old just purchased a 1996 Honda Accord (4 dr). It has about 170,000 miles on it. Just noticed an oil leak near the passenger side tire. Checked the oil and there's not a drop in it. The oil was fine 2 days ago, so this must be a big leak. Could it be the pan, the filter, or is this something more serious like a seal? HELP PLEASE... it only has a 30 day warranty. Don't want to take it back for them to tell me that they fixed it and they didn't and then the warranty runs out. Any help appreciated.
Old Aug 12, 2010 | 03:50 PM
deserthonda's Avatar
i would have it checked out by a professional,, ,, could be a costly repair ( rear main seal )
where the tranny need to come out to replace the seal,
do you see any oil leak while engine is running?? it would be best to have car on a lift to properly see under the vehicle
Old Aug 12, 2010 | 07:16 PM
kris_loehr's Avatar
The counter balance shaft seal would leak about there and pour out. It is behind the front cover. Honda added a retaining ring post production to keep the seal from coming out and wasn’t a recall but a campaign.
Old Aug 12, 2010 | 10:45 PM
that would leak on the drivers side ,,( assuming he is not in the U.K.,, then if engine is opposite you could be correct ..)
Old Aug 12, 2010 | 11:30 PM
kris_loehr's Avatar
Opps My Bad
Can I plea dyslexia
Old Aug 13, 2010 | 06:23 PM
Well if it is a 6 cyl then isn't it "pointing" the other way. Is this a 4 or 6 cyl? The op says "4 dr" not 4 cyl but I'm assuming that is four doors and not four cyl...either way, take it back and get an answer.
Old Aug 15, 2010 | 02:56 PM
4 cylind...sorry forgot to specify. A little has changed in the last few days.... The oil is now holding, but still see a leak behind the passenger front tire.
Front end work was done about 4 months ago. Could this be something else other than oil?
Old Aug 15, 2010 | 06:59 PM
could be a cv boot torn open and grease has leaked out,, it could also be a brake line and or brake caliper leaking, ,, you need to have it checked out by a shop or at least lift car up and chk the leak out yourself,,,,,,,,,if it is clear could also be coming from the a/c drain tube ,, coolant leak ? ..Since you have days left on warranty have it diagnosed properly by a shop to possibly avoid costly repair bill...
all we can do from here is to guess , not a proper way to diagnose things,
Old Aug 16, 2010 | 09:01 PM
Went to the dealership...they said the distributor was leaking. Then they also replaced the heater hose because it was bubbled. Was this from the oil leaking on it? The oil leak stopped for now, but the A/C doesn't work as well. It's blowing, but not as cold. Will the heater hose cause the A/C coolant to diminish?
Old Aug 17, 2010 | 12:11 AM
kris_loehr's Avatar
I know that heater hose well. I believe that is how I blew the head gasket on my 1995. I believe that hose connects to the water valve which controls the temp from a cable and that is what I would be looking out. It may now be out of adjustment. My 95 the valve cover gasket leak did the same thing to that hose.
