Oil leaking from behind exhaust manifold
Old Jan 27, 2012 | 05:13 PM
pancho88's Avatar
Default Oil leaking from behind exhaust manifold
I'm in the middle of replacing my exhaust manifold, header pipe, and catalytic converter, and as I removed the manifold today I noticed some oil leaking out. I don't know what this means and I was hoping you guys could help? Thanks in advance for any advice. I took a picture, you can see it below.
Old Jan 27, 2012 | 05:26 PM
Pull the spark plugs wires and see if any of the tubes are filled with oil. Check around where the distributor meets the cylinder head.
Let us know what you find.
Old Jan 28, 2012 | 04:28 PM
pancho88's Avatar
PAhonda- thanks for the quick reply. I took the plug wires out and they were pretty saturated with oil. I haven't taken the actual plugs out yet, but all the wires were covered in oil; I took some pictures and posted them below. I also took off the distributor where it meets the motor, and there was some oil on the teeth. I took two pictures of that and posted them below. The guy who had the car before me said he replaced the valve cover gasket, but maybe he didn't do it correctly? Maybe he didn't do it at all? I don't think it's the head gasket cause I wasn't having the problems typically associated with that. Thanks for the help!
Old Jan 28, 2012 | 05:17 PM
pancho88's Avatar
Also, for what it's worth, the motor doesn't burn any oil that I can tell, no smoke coming from the exhaust.
Old Jan 28, 2012 | 06:27 PM
I would probably buy the valve cover set and replace all the seals. Felpro (like I said before) makes quality gasket sets that you can get at most parts stores.
The seals on top of the valve cover are pretty simple. Just pay attention to which side of the seal gets pushed into the valve cover, because it can be counter-intuitive.
For the lower seals, google ericthecarguy oil spark plug tubes
This YouTube video shows exactly how to replace the lower seals. It also shows how to install the valve cover gasket.
I would also buy the o-ring for the distributor, because it is a cheap part and you already pulled the distributor.
Old Jan 29, 2012 | 09:52 PM
pancho88's Avatar
Thanks a lot PAhonda, all those seals as well as the valve cover gasket came with my timing belt kit, so I won't worry about it and just install the kit. Thanks so much again for all the help; this forum is awesome.
Hondahonda
Mar 14, 2012 07:55 PM
JerseyTuscani
Jul 2, 2007 05:21 PM
Accord5726
Oct 25, 2005 11:29 AM
remington870_20ga
Jun 17, 2005 03:41 PM
RTexasF
May 15, 2005 06:56 PM
