Oil on spark plug
Old Oct 28, 2008 | 11:13 PM
Antarctica's Avatar
Default Oil on spark plug
I have some oil on my spark plugs, and I know that some gaskets and seals need to be replaced, but I'm not sure which one. I know that the oil leak could be stemming from possibly my lower rocker arm seals or my upper plug seals. I also noticed some oil right outside the front left of my valve cover. Could somebody tell me what signs to look for to determine which one of the two (or possibly both) locations that the oil could be leaking from and instructions on how to change the seals from both locations? Also, what are the negative effects of having oil on the spark plug besides losing oil?
Old Oct 28, 2008 | 11:16 PM
Default RE: Oil on spark plug
buy a valve cover gasket kit, will solve your oil on your plugs(assuming its the upper seal) and your leaking valve cover
Old Oct 28, 2008 | 11:17 PM
finch13's Avatar
First, get a Fel-Pro valve cover gasket set, comes with the VC gasket and 4 upper plug gaskets. If they're still oil, replaces the lower spark gaskets. Still oil, ask for more help.
Old Oct 28, 2008 | 11:21 PM
Antarctica's Avatar
What's so special about Fel-Pro compared to other brands?
Old Oct 28, 2008 | 11:25 PM
Antarctica's Avatar
What materials/tools do I need to install the new gaskets? Anything special?
Old Oct 29, 2008 | 12:51 AM
deserthonda's Avatar
Let your finger do theclicking .. ...go to the DIY section ,there is a step by step write up
Old Oct 29, 2008 | 02:15 PM
jerrym's Avatar
Almost A Senior Member
I replaced my VC gasket and the 4 upper plug seals a few months ago. No more oil on the plugs and a pretty easy job. Do not tighten the VC bolts too much though.
Old Oct 29, 2008 | 02:25 PM
finch13's Avatar
ORIGINAL: Antarctica
They're known as quality gaskets, second best to OEM.
Old Oct 17, 2009 | 09:49 PM
kcd
awesome i believe this will solve my problem of the oil getting on my plugs thnx woo!!!
Old Oct 18, 2009 | 01:26 AM
bemyself
If oil is on ceramic insulator (top plugs) then replace the plugs gasket, if oil is on plugs thread (bottom plugs) then replace the valve seal. CMIIW.
