Ok so now i screwed up
Old Jan 25, 2013 | 08:45 PM
xjncoguyx's Avatar
Default Ok so now i screwed up
I went to run the test on the alternator by testing the plug on it to a ground with the ignition on. So i start the car with the plug unplugged and go to test it and the car shuts off once i touch it to the ground. Turns out im an idiot and never switched it to dc voltage instead it was on dc amperage setting. So i shorted something that's obviously not letting the car spark. My question is what is it wire through.
Old Jan 25, 2013 | 09:18 PM
It may be a blown main fuse. What year car is this and how many cylinders?
Old Jan 26, 2013 | 08:52 AM
xjncoguyx's Avatar
yeah i figured it out after taking a step back for a sec. I check the wiring diagram and that wire runs to the #2 fuse inside under the dash. Must've popped it. Started right back up again.
Old Jan 26, 2013 | 01:11 PM
Good to know it was a simple fix
finch13
Nov 20, 2008 08:24 PM
Buktheng
Feb 11, 2008 06:31 PM
SRG07
Feb 9, 2007 01:25 PM
truevietluv636
Jan 10, 2007 07:36 AM
YeuEmMaiMai
Aug 18, 2006 11:03 PM
