Is it okay to install accord 2008 factory alloy wheel on my 2003 accord
Old Jan 7, 2008 | 12:14 PM
hoonhooon
Default Is it okay to install accord 2008 factory alloy wheel on my 2003 accord
Hello,
I purchased nearly new used 2008 OEM factory wheels& tiresand installed it on my honda accord. But it turned out that my original wheel spec was 205/65-15 (Honda Accord 2003 LX sedan) and the 08 wheel's is P225/50 R17 93V. Is it okay to install thesewheelssincetheseare still honda genuine parts? What are the possible consequences of installing different size wheels and tires? Thanks for your help!
Young
Old Jan 7, 2008 | 12:26 PM
sir_nasty's Avatar
Default RE: Is it okay to install accord 2008 factory alloy wheel on my 2003 accord
As long as the tires fit and the bolt pattern is right the only difference is going to be if one tires diameter is different than the new ones. I'm assuming you're swapping a set of 4 so your speedometer might be off a bit but as long as it doesn't rub you're fine
Old Jan 7, 2008 | 12:37 PM
hoonhooon
Thank you so much! I replaced all four tires andthey seemed little too large to me. The tires and wheelsare not only larger but also wider. That was why I worried about any potential extra stress to the powertrain sysytem, which may cause future expensive repair. It seems that I should be okay except the speedometer error. Neways, I paid $850 for OEM wheel and new tires with 450 mile on it so I think I got a good deal. Thanks!
Old Jan 7, 2008 | 12:43 PM
sir_nasty's Avatar
that is a good deal, and the wider tires aren't going to do much except improve grip. You may lose a little power because of the added weight of the rims/tires but it's not going to make that much of a difference.
Old Jan 7, 2008 | 12:45 PM
hoonhooon
Thanks again. My original wheels were steel and these are alloy wheels, so I am actually expecting less weight and better gas milege. As you say, it wouldn't make that much difference. THanks. I forgot to mention my car model and year. It's Honda accord sedan 2003 LX with manual shift.
Old Jan 7, 2008 | 06:47 PM
HondatechAV6's Avatar
those alloys feel heavier to me. there is only a 1.4% difference in speedo reading so you won't notice any change in speed. but like said - it will feel a lot rougher over bumps and you probably won't be able to spin the wheels as easily as before.
1sarge
Dec 19, 2011 02:23 PM
aztrailrunner
May 20, 2010 01:45 PM
jmmg
Jun 7, 2008 07:33 AM
NYM1
Jun 10, 2006 01:39 AM
nixalot
May 19, 2006 07:04 PM
