one caliper is dragging on 2000 V6 EX
Old Mar 11, 2008 | 08:23 PM
bristang5
Default one caliper is dragging on 2000 V6 EX
I have a 2000 accord V6. I noticed milage dropping and then noted that the car was dragging. I immediately thought that it needed a caliper. Replaced the LH caliper...problem was gone for a day. came back. Warrantied the caliper and put a new one on. Dragging again. I replaced the hose and when I did I learned that the line was holding pressure. Is there a check valve or something that can be rebuilt to allow the fluid to back off?
Old Mar 11, 2008 | 11:06 PM
Default RE: one caliper is dragging on 2000 V6 EX
How exactly did you determine the line was holding pressure? I guess I'm not sure how to believe you about that.
There's a vent port back to the reservoir, that's inside the master cylinder. It only opens up when your foot is OFF the brake. But if the pushrod from the pedal is not adjusted properly, that can mess up the alignment of that port.
Maybe something in ABS, but I think that'skindaunlikely.
jordan925
Jul 11, 2012 05:35 AM
Accord Owner
Mar 6, 2012 08:27 PM
live2rice
Feb 28, 2012 09:15 AM
Jasper
Feb 22, 2009 04:19 PM
tcheema
Jul 5, 2008 09:20 PM
