Out of balance
Old Jul 27, 2005 | 11:16 AM
bkny2780
Default Out of balance
Hi, I have a 2000 Honda Accord 4 cyclinder. It has 118k miles on it. The tires are after market which has about 30k on them. I get a vibration at 65 mph but before that speed it is good to go. The car doesn't pull at all. But driving long distance trips I average 70 mph and that can make for a long trip. I had Sears(where I bought the tires) rebalance the tires a few times but it's still not right. I had another place check the tire rods recently and they said they were okay.
Could this be a strut problem? When I had the other place rebalance the tires they said to start at doing the fronts only. Should I had them do back also?
Thanks in advance
Old Jul 28, 2005 | 06:37 PM
6thgen's Avatar
Default RE: Out of balance
Rotors been changed?
Old Jul 31, 2005 | 04:09 PM
Evlampius's Avatar
Try to rebalance the tires off the car - not the computer on car balance.
also could be damaged wheel/s and/or tires
what brand are you using?
Old Aug 1, 2005 | 03:22 AM
Evlampius has got you going in the right direction, try it his way and you will usually find your problem...
By the way [sm=welcomesign.gif] to the forums
Old Aug 1, 2005 | 10:27 PM
Evlampius's Avatar
also cheap butt tires do that - I would assume you buying some chineese brand at Sears not the one that is at least average for our American roads.
rschmitt2
Jan 6, 2007 08:31 PM
golpha
Nov 25, 2006 12:06 AM
desi01
Jul 8, 2006 06:41 AM
accord4sroy
Apr 22, 2006 02:40 PM
Gummi_67
Jun 7, 2005 12:31 PM
