Balance shaft
Old Nov 8, 2006 | 11:46 AM
golpha
Default Balance shaft
Hello,
I just did the timing belt and balance shaft belts on my 1995 Accord Lx. After everything was together I noticed while accelorating that I get a noise like a loose heat shield. I went back in and found some loose bolts. I also noticed that the front balance shaft has play in it. I mean that I can move the pully back and forth away from the block. I was wondering if this is normal. I thought that it could be the source of the noise, but I don't want to sink money in it if is normal. I also have a problem that occasionaly the car after it is warm will just stall in the driveway while idling in park. I replaced the PCV and it still does this. It sometimes if I hit the gas will idle rough for a little bit and try to idle normally. I think the iac might be going out. Any help on this would be greatly appreciated. I love my car and want it to run right again.
Thank you,
Peter
Old Nov 25, 2006 | 12:06 AM
hondadude's Avatar
Default RE: Balance shaft
balance shaft moves a little normally okay. Pull off the IACV and blast all the crud out of the screen with some good carb cleaner, it probably wouldn't hurt to do a throttle plate cleaning as well. Be sure to use a SOFT brush [toothbrush] so you don't scratch up the throttle plate area
mrwigglezdj
Dec 23, 2007 10:33 PM
slowncurious
May 15, 2007 11:08 PM
quietgiant
Jan 30, 2007 01:37 AM
rschmitt2
Jan 6, 2007 08:31 PM
accord4sroy
Apr 22, 2006 02:40 PM
