Overfilled engine oil
Old Nov 10, 2008 | 03:16 PM
humblehyper's Avatar
Default Overfilled engine oil
Hey guys, I just overfilled my engine with about 0.125 inch above the second marker, is it bad? Do I need to drain a few more? I just changed oil yesterday. Do I have to do it right away?
Thanks!
Old Nov 10, 2008 | 03:25 PM
Tony1M's Avatar
Default RE: Overfilled engine oil
ORIGINAL: humblehyper
Hey guys, I just overfilled my engine with about 0.125a above the second marker, is it bad? Do I need to drain a few more? I just changed oil yesterday. Do I have to do it right away?
Thanks!
What is "0.125a"?
Old Nov 10, 2008 | 05:10 PM
I'm sorry, it's 0.125 inch (half of 1/4)
Old Nov 10, 2008 | 05:14 PM
finch13's Avatar
Lol, no you will be fine.
Old Nov 10, 2008 | 06:20 PM
it will be fine, better to have too much than too little, and trying to drain out just a little would be a pain.
Old Nov 10, 2008 | 06:57 PM
cjdm98's Avatar
lol. I could imagine...
Old Nov 10, 2008 | 07:36 PM
LOL!! I'm worried about engine leak thanks so much guys!
Old Nov 10, 2008 | 07:50 PM
cjdm98's Avatar
engine leakage due to slight overfilling=not likely.
Old Nov 11, 2008 | 08:25 AM
falkore24's Avatar
If it leaks a little, then it will be filled just right! I wouldn't worry about it though, unless you have another reason to be worried. I'll be upping my oil capacity to about 6 qts. pretty soon and increasing viscosity to 10W40 most likely.
Old Nov 11, 2008 | 07:10 PM
Well, you dont increase oil capacity by simply overfilling. Probably getting a bigger oil pan?
Overfilling by a LARGE amount can lead to the crank whipping up the oil into a foam that doesnt lubricate very well.
