Overheating at stops/low speeds
Old Oct 1, 2016 | 11:44 AM
As TX said, a pressure tester will help in finding the leak......those little heater hoses under the dist seem to like to leak, usually because the o-ring at the base of the dist will go bad and allow oil to leak onto the hose causing it to become weak
Old Oct 2, 2016 | 05:51 PM
Thorsteenster's Avatar
Yeah, that one already got me when I got the AC working, it blew that hose. Which was also nice in that it fixed my oil leak! lol
Old Oct 4, 2016 | 09:56 AM
So if it is the heater core, it would only leak with temp set to hot, yes?
I've never pressure tested a cooling system before; should I have the heat valve open, do I need to do anything with the t'stat?
Old Oct 4, 2016 | 10:21 AM
No, heater flow valve only isolates flow to the heater core. Pressure will equalize across the valve from return side. Thermostat has a small bypass that allows pressure to equalize w/ a closed thermostat.
Pressure tester is available for loan from AZ, etc. Be sure they have adapter for your radiator.
Old Oct 28, 2016 | 09:36 AM
Well, when I had gone out to check, the system and reservoir were still full, so I put it off and it's been fine up until yesterday, and yes, I had been slacking off on checking since it was good for a week.
I'm guessing it is the heater core, having the heat on yesterday morning was supplying plenty of AF odor. My thinking is if I'm not seeing any sure signs, wet carpet, windshield residue, I may not see anything pressure testing. So for now, being the weathers dipping at night i'm going to drain and refill with mix instead of just water and bypass the hater core for the time being.
Old Oct 28, 2016 | 11:21 AM
Check heater core connections on outside of firewall. Sometimes they can leak into pax compartment.
nickmg555
Mar 6, 2012 07:26 PM
kakarotoni
Sep 14, 2010 07:12 PM
800rmk
Sep 14, 2010 05:50 PM
Nitin
Apr 20, 2008 07:19 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
