oxygen sensor replacement
Old Aug 21, 2010 | 11:56 AM
jackfast's Avatar
Default oxygen sensor replacement
how crucial/beneficial is this?
my error codes tell me that my sensor is bad.
new sensor is around $60.
other than getting the 'check engine light' to turn off, why should i replace this?
the car runs good, gas mileage is ok...
Old Aug 22, 2010 | 05:49 AM
jackfast's Avatar
anybody?
Old Aug 22, 2010 | 08:43 AM
which code did you get?
That sensor is used to adjust the air/fuel mixture, so you should get better gas mileage with a new sensor.
Old Aug 22, 2010 | 05:47 PM
piggylover1985's Avatar
Your car may not pass emission if your state require one. It may run rough, poor fuel economy. Could destroy the catalytic converter later on.
Old Aug 22, 2010 | 06:07 PM
You could get slightly less gas mileage, I have been running mine with a faulty one for a few years and still get 32mpg. But you won't pass inspection with the CEL on if your state has inspections.
Old Aug 22, 2010 | 06:43 PM
Depending on how bad is the sensor. I had a 91 before with a bad O2 sensor, it barely drivable, every time i gave it gas, it flooded out, i can smell raw fuel came out the tail pipe.
3dw1n
Jan 14, 2015 01:53 AM
Enloeeagle
Jul 1, 2013 06:44 AM
dmost30
Sep 8, 2008 12:42 AM
dmost30
emills
May 12, 2006 03:03 AM
