Oxygen sensor wiring
Old Apr 5, 2008 | 01:19 PM
imjrk's Avatar
Default Oxygen sensor wiring
Need some wiring help for the Oxygen sensor on the exhaust pipe on a '96 Accord SE, VTEC, automatic. Wires got pulled out of the plug while changing the engine.
On the Oxygen sensor the wires are two black wires, one white, one green;
on the engine side of the plug they are orange/w black stripe, green/w black stripe, white/w red stripe and yellow/w black stripe.
Thank You
Old Apr 5, 2008 | 06:50 PM
Default RE: Oxygen sensor wiring
Heater circuit is yel/blk and org/blk. These connect to two black wires, either way.
The wht/red probably matches white and grn/blu matches green. However, I wired a universal O2 sensor once and got it backwards. Some googling on universal O2 sensors should turn up the wiring matches. You can temporarily connect wires, try it out, and if check engine light comes on, you've got it backwards. That's what happened to me.
Old Apr 5, 2008 | 08:25 PM
imjrk's Avatar
Thanks, I'll give it a shot.
3dw1n
Jan 14, 2015 01:53 AM
dmost30
Sep 8, 2008 12:42 AM
dmost30
mdjohn
Feb 18, 2006 04:28 PM
93AccordLX
Nov 21, 2005 09:22 AM
