Oxygen sensor wiring
Need some wiring help for the Oxygen sensor on the exhaust pipe on a '96 Accord SE, VTEC, automatic. Wires got pulled out of the plug while changing the engine.
On the Oxygen sensor the wires are two black wires, one white, one green;
on the engine side of the plug they are orange/w black stripe, green/w black stripe, white/w red stripe and yellow/w black stripe.
Thank You
Thank You
Heater circuit is yel/blk and org/blk. These connect to two black wires, either way.
The wht/red probably matches white and grn/blu matches green. However, I wired a universal O2 sensor once and got it backwards. Some googling on universal O2 sensors should turn up the wiring matches. You can temporarily connect wires, try it out, and if check engine light comes on, you've got it backwards. That's what happened to me.
