P0325 fault code
Old Mar 8, 2020 | 02:15 PM
AZVince's Avatar
Default P0325 fault code
I have a 2010 Honda Accord, V6, with fault code P0325. That is a Knock sensor 1 code. But, as soon as the CEL lit, the ECO mode was Not operational. Last year, I had fault code P3400 Valve Pause System stuck OFF. Honda Tech bulletin said to check engine oil. Since the ECO mode was Not operational this time, I stopped and checked and the engine Oil was low, just at the tip of the dipstick. My question is: Will the P0325 code now present (Note: this is the only code, no others shown) affect the ECO system like the previous fault code did? I am confused. I did add a qt of oil to bring the level up to 1/2 on the dipstick.
Old Mar 8, 2020 | 04:13 PM
The PCM may disable the eco mode if it sets a P0325. You'd almost need a scanner to see if any systems are disabled.
Since you have the P0325, you should start by troubleshooting the code. The code can be set by a bad knock sensor, faulty wiring to the sensor, or the PCM. At minimum, unplug the kock sensor and look for any corrosion in the connector. Also look for signs of damage to the wire harness nearby.
Fomoco1
Nov 21, 2012 01:56 PM
Nightintruder
May 16, 2012 05:39 PM
Hondaccord
Jan 30, 2008 06:30 PM
gerar
Aug 10, 2006 12:11 AM
biglarge
Nov 27, 2005 03:21 AM
