P0420 and P0133 codes
Old Mar 25, 2013 | 07:22 PM
Dakota21601's Avatar
Cool...I will have to start tinkering.....lol. Although, how do you troubleshoot whether the 02 is jacked or if it is throwing a code due to something like an injector? You have to just buy the 02 new and see if it does the same? Any issues with using a non Honda 02? I know the Dodge Rams hate the Bosch 02's. That's why I ask.
Old Mar 25, 2013 | 08:52 PM
Denso makes the O2 sensors for Honda. But I'd get the proper fit one, with the plug. Not the generic one where you have to splice the wires.
People say that Hondas don't like Bosch spark plugs, but I haven't heard that for O2 sensors. Anyway, Denso is easy to find at lots of parts stores.
You can check the O2 sensor wires for being loose/dirty/corroded? Insulation rubbed away? Anything silly like that? If you're ambitious, you can verify continuity in the wires back to the ECU. But I don't know the ECU pin-out so maybe someone will chime in.
Old Mar 25, 2013 | 09:14 PM
Thanks for all the help!
Old Mar 26, 2013 | 09:12 AM
firefighter44's Avatar
Almost A Senior Member
There is also a "shadetree" way of bench testing it using a propane torch but it has to be done just right and you can achieve the same results by testing with a multi meter while the car is running and the sensor is heating naturally via exhaust gasses flowing over it
anticrom
Aug 3, 2013 10:20 AM
capthoward
Jun 25, 2011 07:25 AM
PiksPal
Dec 31, 2010 10:03 AM
southernboagurl
Jun 2, 2009 06:22 PM
tonylanz
Sep 16, 2008 06:08 PM
