P1167 Bad O2 sensor 02 Accord SULEV
Old Nov 14, 2015 | 04:46 PM
mclasser's Avatar
Default P1167 Bad O2 sensor 02 Accord SULEV
Got a CEL this morning with code P1167. Appears the front O2 sensor (A/F sensor ratio as Honda calls it) is bad. Car has a rough idle and some upper engine chatter but otherwise pulls hard and strong. Did some research and the Denso 234-9014 is a direct replacement for an otherwise exorbitantly expensive part from Honda for my SULEV engine.
The sensor looks pretty easy to get to. Do I have to use a special O2 sensor socket or can a 22 mm open ended wrench do the job? Thanks!
Old Nov 15, 2015 | 09:22 AM
It may require removal of the exhaust heat shield to access w/ an open end. You should be able to determine by inspection whether hex pattern is above the heat shield. If not, heat shield will have to be removed or O2 socket tool necessary. Special sockets are available for loan at some parts stores.
Old Nov 15, 2015 | 09:38 AM
Turtlehead's Avatar
You will likely break the bolts on the heat shield if you try and remove them to use a wrench. Just is an O2 socket and you will be fine. Run the car to get the engine hot and the almost always break free with no issues.
giulio76
Dec 29, 2012 11:16 AM
mady2010
Aug 25, 2010 10:12 AM
redbull622
Oct 23, 2009 05:06 PM
tobydog
Apr 20, 2008 06:53 PM
vvv_vtec
Feb 17, 2008 01:48 PM
