P1298
Old Nov 20, 2007 | 07:53 PM
shaney
Default P1298
Need help,need help,need help!.I cannot pass insp. due to code 1298 ELD high volt. I troubleshot according to Haynes. I bought new alt.and a newELD w/ the fuse box it is housed in since this is the only way Honda sells it.I'm still getting the code P1298.[X(]2001 Accord EX 5spd.[X(]
Old Nov 20, 2007 | 09:49 PM
nmikmik's Avatar
Default RE: P1298
[ul][*]TSB #07162005 -- IF THE BLK/YEL WIRE IS SHORTED TO GROUND AT THE REAR OF THE NON ULEV ALTERNATOR, THE ECM/PCM MAY RETAIN DIAGNOSTIC TROUBLE CODE P1298, P0141, P0135, P0753 OR P1753 AND THE NUMBER 6 FUSE IN THE DRIVER'S UNDERDASH FUSE/RELAY BOX MAY BLOW INTE (NHTSA ID #10018077, JULY 16 2005)[/ul]dono, maybe it's the short in the wiring i.e. past the alternator.. Did you recently do anything to the electrical system? was it recently in the fender-bender? Did you clear the old code after installing new alternator?
Old Dec 2, 2007 | 07:10 PM
HondatechAV6's Avatar
Default RE: P1298
yeah, check fuse 6 in the drivers underdash fuse box. if it's blown, check the alternator wiring near the alternator for the short to ground. isolate and repair the damaged wiring and replace the fuse.
Old Dec 3, 2007 | 10:19 AM
00AccordLX5spd's Avatar
Registered User
Default RE: P1298
ORIGINAL: HondatechAV6
Haha! That's easier said than done!
Old Dec 3, 2007 | 06:44 PM
Default RE: P1298
true, it usually is easier said than done. but it usually rubs through the isulation near the alternator. between the alternator and the p.s. bracket that holds the harness.
dtridente
Jan 3, 2013 07:46 AM
