P1399 & p0441
Old Mar 30, 2018 | 09:05 AM
TexomaAccord's Avatar
Default P1399 & p0441
Pending codes on this now.. Ugh
I know the evap is when I prolly broke the connector and put tape on it.. So thoughts on p1399?
Old Mar 31, 2018 | 07:05 AM
Or is one causing the other?
The "pending" misfire (1399) could be a result of the evap issue, if the ECU/PCM is expecting flow from the evap to the intake and adjusts for it but it is not there - well you start messing with the air/fuel ratio.....at some point if those are too far out of line you will get a misfire.
Again, just food for thought.
Old Mar 31, 2018 | 09:05 AM
i have had the evap one for awhile now, the misfire one is newest
krnluve24
Nov 12, 2014 10:07 AM
Kludge
Feb 19, 2013 10:03 PM
teahtime
Aug 5, 2011 08:44 PM
rdrx7
Aug 25, 2009 07:49 PM
