P1456 - Just changed my gas cap, that wasn't it
Old Aug 28, 2012 | 09:28 PM
LordAccord's Avatar
Default P1456 - Just changed my gas cap, that wasn't it
Hi all, thanks to everyone who helped with my power steering issue. I located the problem and am on the way to getting it fixed. I've had this error code for about a month now. I have an EVAP leak/problem, but the leak is not at the tank nor the motor, as both were checked out for me. I also changed the gas cap as thats the most common reason for the error code, but to no avail. I know none of you can tell me exactly what my problem is, but how can I tell where the problem might be? I'm trying to get a DIY mentality with this car as funds are low, and I really need to get an inspection sticker. But my engine light won't go off. Thanks in advance everyone
1998 Accord EX V6 3.0
Old Aug 28, 2012 | 09:41 PM
Do you live in the north, where there is a lot of salt on the roads in the winter?
P1457 is a more common problem on these cars. If you are near a parts store, have them rescan just to be sure you got the correct codes.
Old Aug 29, 2012 | 12:47 AM
LordAccord's Avatar
I do live in the northeast, in NYC to be exact, but this car was purchased in Florida then driven back. I've had Autozone and Advance do a error scan, and always the same result. Both in Florida and NY. I also notice that when I drive around, after 10 minutes or so I smell gas.
Old Aug 29, 2012 | 12:51 AM
my1st.honda93's Avatar
ok now im back,so what is the code saying?in english not numbers an we will find your solution
Old Aug 29, 2012 | 01:47 AM
Old Aug 29, 2012 | 01:54 PM
LordAccord's Avatar
Basically what the link above describes. It doesn't effect my driving, nor is it a safety issue but I want to pass inspection and this might prevent me from doing that.
Old Aug 29, 2012 | 04:04 PM
check your purge canister mite be saturated?
Old Aug 29, 2012 | 05:22 PM
Dis_ill_usions's Avatar
I am a GM tech and most commonly when I get an EVAP leak it turns out to be a EVAP vent solenoid. I know GM and Honda vehicles differ greatly, but that is just my .02. Kind of difficult to check without the proper scan tool, but with GM's there it a function to seal the system (force the purge and vent closed) then you introduce smoke in the system. If the vent is leaking, smoke will come out there.
I know you said you live in NYC but do you happen to drive on dirt roads at all? That tends to be the most common reason I see as to why the vents go bad, dirt gets trapped and does not allow the vent to close.
Old Aug 29, 2012 | 05:28 PM
Here's a Honda TSB for Honda techs:
Honda TSB 99-075
Old Aug 29, 2012 | 06:09 PM
I'd say...start there ^
