p1696 code?
Old Apr 21, 2012 | 01:04 PM
corolla42091's Avatar
Default p1696 code?
Ok....I have the 99 accord....I just swap in the f20b n the f20b ecu....n after getting it to run...when it goes thru the gears its real sluggish ...I have the cel on...so when I took it to get the code it came up with one code..p1696...I guess that's the pm code...so what should I do? Get another f20b ecu?
Old Apr 21, 2012 | 01:05 PM
Pcm *
Old Apr 21, 2012 | 08:26 PM
Dr. Drivability's Avatar
not a valid code for that ymm, what year is the engine and computer out of?
Old Apr 21, 2012 | 09:38 PM
the motor is a yr 2000 comes out of the honda accord sir....the ecu is the same yr
Old Apr 21, 2012 | 09:51 PM
P1696 PCM Failure EEPROM Write Denied .........that is what the code means....im just not sure about do i now have to change the ecu?
Old Apr 21, 2012 | 10:09 PM
that may be what the generic code is but the o.e. website is not showing any such code for 99 or 00
Old Apr 21, 2012 | 10:31 PM
well i put the old ecu (f23 ecu ) back in my car...n the tranny runs good...but the motor doesnt cuz it doesnt have the correct base map......so it makes sense that the pcm is bad.....cuz the f20b ecu makes the tranny run real sluggish ...hesitation........
usmrocks
Nov 28, 2010 09:32 AM
tingjunkie
Sep 17, 2010 06:37 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
