P1753 code when testing CEL
Old Feb 25, 2009 | 10:37 PM
wish234's Avatar
Default P1753 code when testing CEL
i looked up the code online and it says its a problem in Torque Converter Clutch Solenoid Valve Circuit Comprehensive. Does anyone know what that means and what i should look for ?
Old Feb 26, 2009 | 02:43 PM
Check the two-pin connection going to the solenoid on the tranny in the pic below.
The resistance between the two pins should be between 12-24 ohms.
You can get a 94 accord shop manual from Online Manuals thread in the DIY section. That will have the proper info for testing/replacement of the tranny solenoid. The only difference is that the code numbers are different for a 94 (OBD1) vs the 97 (OBD2). Everything else is pretty much the same.
Old Feb 26, 2009 | 02:45 PM
You may also just have to clean that screen and solenoid with some throttle body cleaner. It may have gotten clogged over time.
Old Feb 26, 2009 | 04:43 PM
wish234's Avatar
i will check the connector and may try and take off the solenoids and clean them. Will i need a new gasket ? Can you get those at autozone or a parts store or do you have to from Honda ?
karmajay
May 11, 2017 09:32 AM
Khai Son
Mar 14, 2012 11:32 PM
tingjunkie
Sep 17, 2010 06:37 PM
Stener75
Jul 25, 2010 08:21 PM
appleman
Sep 27, 2007 11:44 AM
