panel lights
Old May 18, 2017 | 09:53 PM
talpog's Avatar
Default panel lights
Hello there! I have a 2004 accord lx and my problem is the radio and a/c panel lights stopped working. They used to light up from time to time until it completely died. I was thinking probably a loose connection because the fuse is ok, no problem with the radio and a/c, just the panel lights...help please!!!
Old May 18, 2017 | 11:22 PM
Is the display not showing anything like in this post? If you attempt this, replace with the 2.4 ohm resistors.
No Display Radio Fix - Drive Accord Honda Forums
Old May 19, 2017 | 05:15 PM
talpog's Avatar
Thanks for replying PAhonda, but the radio is fine and the backlight is working, as I've said, only the panel lights (radio, a/c, and gear shift lights are out). The fuse is fine.
Old May 19, 2017 | 05:16 PM
talpog's Avatar
I just want to know the connections of these panel lights so I can check them.
Old May 23, 2017 | 09:59 AM
talpog's Avatar
It's ok guys...got it covered!
Old May 23, 2017 | 06:37 PM
Sorry that your question slipped through the cracks.
I'm not sure how the bulbs are connected wired.
Did you figure out the problem?
Old May 27, 2017 | 09:27 PM
talpog's Avatar
Yeah and I was right all along...just a loose connection, all bulbs are ok except for the shift gear bulb. Thanks anyway!
ekg98
Dec 20, 2013 10:20 AM
naimperez
Oct 2, 2011 07:01 PM
allansamberg
Feb 7, 2008 11:19 PM
anton17
Aug 30, 2007 06:02 PM
