Parking Brake and TCS indicator come on.
Old Jul 5, 2008 | 04:46 PM
2003 V6
Default Parking Brake and TCS indicator come on.
Dear Accord Enthusiast!!
I have a 2003 accord V6.
I've bleeded my brkae system yesterday. the procedure is just like as is.(evacuate fluid reservoir and refill with new fluid and bleeding 4 wheels from further to closer))
After that, I recognized that the parking brake indicatro and TCS activation indicator came in.
I thought the level of brake fluid maybe lower than normal. so I bought a honda genuine brke fluid (heavy duty DOT3) and refilled. However those two indicator still won't turn off.
please let me know what do I have to do and what's the problem.\
Let me ask one more question about brake pads. I replaced front brake pads last month because of squealing sound (the brake pads still remain more thna half.). After replacing the pads,squealing sound didn't go away. What should I do to remove the noise?
The last moremiscellaneous question is about sprk plug. Have you ever heard about "Pulse spark plug"? Does it work?
Thank you.
I'm really waiting your precious answer. ( The first question is the urgent one)
Enjoy your ride!!!
Old Jul 6, 2008 | 10:16 AM
Default RE: Parking Brake and TCS indicator come on.
Hello New Member
Please post in the correct forum when you post.
Thank You for joining the forums...
Old Jul 6, 2008 | 03:34 PM
YeuEmMaiMai's Avatar
is your brake fluid level sensor working?
is your parking brake switch working?
to get rid of squeal usually one appliesanti squeak to the back of the pads and shims but a lot of time semi metallic pads squeak no matter what
Old Jul 15, 2008 | 11:41 AM
2003 V6
Dear Dude!!
Theparking brake switch works well and
After replacing brake fluid, the braking get pretty better than before.
I don't know whether the brake fluid level sensorwork or not.
Would you let me know how to check the sensor?
Thanks.
Old Jul 15, 2008 | 04:38 PM
falkore24's Avatar
D@MN HAF!!!
Old Jul 16, 2008 | 08:02 AM
Dont have to scare off the new guy...
https://www.hondaaccordforum.com/Sti..._128656/tm.htm
mamtsberg
Sep 10, 2012 08:58 AM
DerekWildstar
Jun 18, 2012 11:06 PM
asmerik
Jan 21, 2011 01:38 PM
2003 V6
Jul 6, 2008 10:16 AM
nrangerfan
May 20, 2005 01:57 AM
