passenger side "blinkers" on the blink!
Old Apr 6, 2015 | 12:59 PM
michael3504's Avatar
Default passenger side "blinkers" on the blink!
2005 honda accord, v6. no right side blinker indicator comes on inside, nor does the passenger front or rear, does not come on when the hazards are on neither, all driver side blinkers, hazards work though, including inside indicator. Any clues to my problem? relay somewhere? or blinker switch in steering column? checked all fuses and they were good.
Old Apr 6, 2015 | 01:16 PM
Default "blinkers" on the blink
Hang with me, my first time on here. I have a 2005 honda accord v6, at. The blinkers on the passenger side do not come on, nor does the panel indicator (right side), nor do they come on with hazard button engaged, all that works is the driver's side. Is there a relay somewhere? hope it's not the switch in steering column! Any advice would be appreciated!
Old Apr 6, 2015 | 02:08 PM
The turn signal hazard relay is located in the driver side under dash fuse relay box.
Old Apr 7, 2015 | 07:30 AM
Thank you sir, the serial number/code retrieval was testy enough, whew! but it looks like I might get lucky on this one, once again, thanks!
ryanw2427
Sep 19, 2012 08:39 PM
sbi
May 19, 2012 08:38 PM
HondaAficionado
Nov 30, 2010 05:24 PM
19accord92
Apr 10, 2006 03:52 PM
