Passenger window won't roll up
Old Feb 17, 2012 | 03:19 PM
You can try adjusting the front channel and glass as shown in this Honda technical service bulletin:
http://www.driveaccord.net/forums/at...5&d=1079378099
Although this TSB is regarding the glass coming out of the channel, in your case, it may be binding. You may also want to clean the channel with rubbing alcohol and q-tips and than add silicone grease or spray to the channel run afterward.
Old Feb 17, 2012 | 04:01 PM
Search for v=D1svF3Pmolc on YouTube.
This is a video on replacing a run channel on an accord. You may be able to just use some silicone paste on the inside of the run channel to see if that helps. The video should show you how to remove the run channel.
Old Feb 17, 2012 | 08:03 PM
phatboyslim2012's Avatar
pa and redbull im going to start a new thread, kinda thread jacked on the op. ill ad link here for the new thread.
djkurious
Sep 2, 2013 03:20 PM
savoiu
Aug 28, 2012 11:12 AM
92tealaccord
Apr 9, 2012 02:25 PM
crvone
Jun 13, 2011 11:45 AM
romel123456
Feb 5, 2008 04:17 PM
