PCV Valve Confusion Honda Accord LX 2000
Old Sep 10, 2011 | 10:07 AM
nufftalon's Avatar
Default PCV Valve Confusion Honda Accord LX 2000
I am bit confused I went to advanced auto parts to get a new PCV Valve they gave me that looks like this
Buy Beck/Arnley PCV Valve 045-0262 at Advance Auto Parts
Mine has the part in the engine and on the hose has another part. It's not one whole piece like the one they gave me.
My question is the part in the hose it seems pretty tight does it come out?
Or do I have the wrong PCV Valve? I was trying to do it myself because he said it just pops out and the other one pops in but its different.
I didn't take this picture but this is what my engine looks like. So basically my PCV Valve is on top of the engine.
http://www.google.com/imgres?q=honda...:429,r:10,s:24
Thanks
Old Sep 10, 2011 | 10:46 AM
Moved to Gen Tech.
This is a 4 cyl, correct. Not sure of what you have, part in the engine, part in the hose....kind of sounds like the onld one broke. If it is a plastic piece in the hose, yes it should come out. See if this pic helps, PCV is #2?
Old Sep 10, 2011 | 10:51 AM
nufftalon's Avatar
it is a 4 cylinder yes. I will take a picture of it on my break. Of my actual engine that would probably be the best thing thanks for the help.
I do know that the piece thats on the hose pops on to the piece on the engine it didn't look like it was broke to me. I will double check it though and take some pics.
Old Sep 10, 2011 | 12:39 PM
nufftalon's Avatar
Hopefully these pics will give you a better idea I just took them.
Old Sep 10, 2011 | 12:57 PM
The new part you bought as indicated in your first post is the correct part.
The used one in the pictures of your engine is a different PCV valve with an angled adapter.
PCV valve are relatively simple devices.
Old Sep 10, 2011 | 01:01 PM
nufftalon's Avatar
oh ok so the part in the adaptor part in the hose I should be able to just pull that black part out right?
Im a noob at this stuff but trying to get some knowledge under my belt.
Honda_Lady's Avatar
yea it broke dude. it's not supposed to come apart like that and the one you gave a link to for the new one is the right part. when it comes to the PCV valve though i usually get it straight from Honda though the one i got from Advance didn't work so i took it back and went to the Honda dealership.
Old Sep 10, 2011 | 01:03 PM
Honda_Lady's Avatar
yes the part in the hose should come out. it makes it easier when you take a flat tip screw driver and push on the hose and pull on the plastic part.
Old Sep 10, 2011 | 01:04 PM
Yes, it should pull out and not be needed.
Old Sep 10, 2011 | 01:11 PM
nufftalon's Avatar
thanks everyone ok great gonna check the dealership for the part and I just wanted to make sure before I pulled it out.
