please help heat problem
Old Dec 10, 2011 | 10:04 PM
tedmar's Avatar
Default please help heat problem
i have a 94 honda accord. the car will heat up like normal but after i turn on the heat the heat gauge will go down i can literally watch it go all the way back down to cold. sometimes the heat will only get a little cold other times it will get completely freezing what's going on with twenty degree nights i need heat lol please help
Old Dec 11, 2011 | 01:49 AM
I would replace the thermostat and while you are at it, replace the coolant. Get the thermostat from the honda dealership, because it will open at the proper temperature and last for a long time.
Old Dec 11, 2011 | 09:03 AM
^ T-stat stuck open Be sure to bleed the air out of the cooling system after replacing....Honda's don't like trapped air in the cooling system.
Old Dec 11, 2011 | 11:04 AM
tedmar's Avatar
ok ill go get a thermostat can a get one from any accord or does it have to be a specific year because i have all kinds of junk yards i can get one from.
Old Dec 11, 2011 | 12:00 PM
Get a new one. If you don't get it from the dealer, at least get one from your local parts store,,,,aftermarket ~$10 and worth every penny....dealer ~$20 (check me), still worth every penny....I'm poor (really) and I would not even try a junk yard t-stat.....
Old Dec 11, 2011 | 12:40 PM
bigpat's Avatar
Almost A Senior Member
I have had faulty new aftermarket t-stats in the past. If you go that route, you may wish to test it in boiling water prior to installing it. My factory Honda t-stat was $21.68 from Honda dealership. You can find the Stant aftermarket at about any autoparts store...About $9.50.
Old Dec 12, 2011 | 09:40 AM
tedmar's Avatar
would a dealer even still have a t-stat for a 1994 accord seems old for a dealership and also what is the boiling trick and where is my t-stat located? thank you
Old Dec 12, 2011 | 11:09 AM
bigpat's Avatar
Yes, the Honda dealer will have your t-stat...They had mine for my 1993 LX. It is a fairly universal part, but with a variety of heat ranges. In California, I was told that the 190 degree t-stat is what was recommended. To test the part, boil a pot of water and drop in the new t-stat. It should open faily quickly. If not, then the t-stat is bad/defective.
To find it on your car, follow the top radiator hose to the front of the engine block. The hose will be mounted to a round shaped aluminum housing that is secured with 2 bolts. That is the t-stat housing, and will need to be removed to access the part. I would get the service manual for this or look for complete directions here in the DIY section. You will need to drain the coolant, replace the t-stat and gasket, refill the coolant and bleed the air out correctly.
Old Dec 12, 2011 | 05:34 PM
Follow the lower radiator hose, to the thermostat housing on the engine block.
Old Dec 12, 2011 | 06:11 PM
Good catch my friend.......yes, on almost anything 4th gen and up, follow the lower hose. Now if this was a 3rd gen (86-89), but that is a different story.
