Please Help No Power to the Driver side Fuse Box
Old Jul 7, 2012 | 04:38 PM
RomeoOG's Avatar
Default Please Help No Power to the Driver side Fuse Box
Hey people,
Usually I can figure out whats wrong but I have try everything I can and still at lost, Its a 99 accord LX Sedan...
Lately I notice that my Cruise Control don't work so last night I came home from work and decided to check it out, I been reading and research on the web and going off that I have learn to check for. Anyways first thing I did was change out the bulbs on the master witch on the left handside of the steering wheels.
Next thing is I pull out the switch that goes to the brakelight switch well its tight as a **** from being in there for so long, anyways I got it out to test everything test ok. So I decide to take out the brake light switch itself to see how it is. Anyways the bolt that holding it was another **** to get it loose but I got it off while doing all this my dump *** left the keys on and was listening to the radio.
Anyways When I try to put everything back now I have no power to the interior or the fuse box on the driver side the one underhood and on the passenger side still gets power. I have check every fuse and all fuse is fine. Have I burn out something? Can anybody body point me in the right direction. Also I thought the old brake light switch was the problem so I took it apart so Its **** up so I went and got another one still no power to the inside when I turn the key to on nothing is on, horn still works when open the door lights turns on.
Is there a relay or something that controls everything else?
Old Jul 7, 2012 | 04:41 PM
what year, model, etc... accord do you have?
Old Jul 7, 2012 | 04:47 PM
RomeoOG's Avatar
1999 accord LX
Old Jul 7, 2012 | 05:02 PM
V6 or 4 cylinder?
So none of the fuses in the driver's side fuse box have no power?
What components inside of the car are not getting power now?
Old Jul 7, 2012 | 05:15 PM
RomeoOG's Avatar
V4,
turn the key on no power no radio, no dash lights, is there a relay that controls main relay?
I even took the Main relay off and check the inside nothing look burn. Put Brake light after install new unit works but still no power.
Old Jul 7, 2012 | 05:24 PM
Double-check the No. 21 (50A) large fuse in the under-hood fuse box. See attached pics.
If replacing, disconnect the negative battery cable first before working on it.
Attached Thumbnails Please Help No Power to the Driver side Fuse Box-under-hood-fuse-box.jpg   Please Help No Power to the Driver side Fuse Box-checking-large-fuse.jpg
Old Jul 7, 2012 | 05:38 PM
RomeoOG's Avatar
Already check Fuse still good, check every other fuse also still good thats why im lost not sure which one runs the fuse box inside.
Old Jul 7, 2012 | 06:20 PM
RomeoOG's Avatar
Any other place that runs electrical into the interior and fuse box?
Old Jul 7, 2012 | 06:26 PM
The No. 21 fuse in the under-hood fuse/relay box was one that ran power into that side.
Old Jul 7, 2012 | 06:43 PM
RomeoOG's Avatar
Does the main relay has anything to do with it?
