please help running out of ideas
Old Jun 22, 2012 | 12:44 PM
smily1983's Avatar
Unhappy please help running out of ideas
Ok i have got a 95 accord ex v6 with auto transmission. I have a misfire in cyl 6. i have replaced the (speed censer, spark plugs, wires, distributor, and cap) there is still no change. The car runs real rough. Transmission has problems shifting at times. Compression is good in all cylinders. Speedometer goes crazy at times but tac, odometer, and cruse control work fine. Car always stars but with a rough idle, and the misfire is constant. The only code that comes up is a cyl 6 misfire. Im lost now not sure what to try next. Just looking for any advice, any at all. thank you and have a blessed day.
Old Jun 22, 2012 | 01:48 PM
Dr. Drivability's Avatar
pull the pigtail off of injector number 6 and if there is little or no change replace the injector, double check your spark plug in that hole as well.
Old Jul 2, 2012 | 10:58 AM
smily1983's Avatar
Default still need help please
Ok thank you for the advice. I removed the pigtail and there was no change so I switch the injector with five just to make sure it was the injector. The code still comes up cyl 6 misfire, also the plug is still fine.any other suggestions would be appreciated thank you.
Old Jul 2, 2012 | 11:08 AM
Silver6gen's Avatar
get a spark tester plug and put it on the plug for cyl 6. See if you are indeed getting spark to that plug.
Old Jul 2, 2012 | 11:23 AM
The problem may be caused by clogged EGR ports. Your 95 Accord V6 has a removable EGR port service plate that makes for pretty easy cleaning. See attached pics.
Attached Thumbnails please help running out of ideas-95-97-accord-v6-egr-port-service-plate-page-1.jpg   please help running out of ideas-95-97-accord-v6-egr-port-service-plate-page-2.jpg
Old Jul 2, 2012 | 01:30 PM
could be a burned exhaust valve too
egerms
Mar 27, 2013 09:38 PM
mikes_accord
Mar 15, 2013 07:41 AM
apogeeren
Dec 23, 2010 09:21 AM
90accord90
Jan 25, 2010 03:28 PM
milano_6
Sep 28, 2007 01:19 AM
