Plugs and wires for 96 Accord 4 cyl
Old Nov 3, 2007 | 08:43 PM
NALANALA
Default Plugs and wires for 96 Accord 4 cyl
What brand of plugs seem to do the best in a regular 4 cyl honda accord. Non vortec. Also under the hood it says gap is 1.1 mm , what it this in inchs , like 28 to 30 thousants or what.
Old Nov 3, 2007 | 11:58 PM
deserthonda's Avatar
Default RE: Plugs and wires for 96 Accord 4 cyl
use NGK ZFR5F-11 gap specs .038-.042 in, gap them at the smallest setting ( .038 in ) as plug gap gets wider as they wear.
Plug wires,,,,, use honda factory plug wires ,, they are very good and they last a long long time
Old Nov 4, 2007 | 12:08 AM
Calm_B4_Chaos's Avatar
The guy who sold me my car said that.... I didnt believe him... I bought a new set of wires when i changed the plugs ... I kept my factory wires ... should i put them back in?
Old Nov 4, 2007 | 06:59 PM
Clean up the wires & keep them. Chances are your new ones will wear out then put the factory ones back on. Unless you have lots of mods, the factory plugs & wires are very good.
What kind of new wires did you get? NGK wiresare also supposed to be very good.
Old Nov 5, 2007 | 05:20 AM
Chiovnidca's Avatar
ORIGINAL: NALANALA
1.1mm = .043"
Old Nov 5, 2007 | 08:43 AM
ORIGINAL: JimBlake
I bought a cheap set of DuraLast wires... the plugs are NGK though
Old Nov 5, 2007 | 03:11 PM
00AccordLX5spd's Avatar
Registered User
The plugs come pre-gapped, so don't go crazy with a gap tool. Simply check the gap. They should all be withing the correct specs already. You can get a gap tool for like $0.50 at AutoZone if you don't already have one.
Old Nov 5, 2007 | 03:55 PM
brittanym06's Avatar
I put off-brand plug wires from AutoZone on my Honda and the darned things went out after less thansix months.....I would suggest spending a little more and at least getting name brand wires, if not Honda.
Old Nov 5, 2007 | 04:18 PM
Registered User
Sumomito is OEM, I've been told. I haven't replaced mine, but I think they are pretty pricey
Old Nov 5, 2007 | 06:39 PM
ckebottle's Avatar
ORIGINAL: NALANALA
I think all hondas are non vortec
and 00 yeah, they are sumitomo. i bought the oem ones from local dealer for 74.07. woot.
SeattleDude84
Jul 14, 2011 11:36 AM
19Accord97
Dec 12, 2007 09:36 AM
onedollaraccord
Mar 26, 2007 10:13 AM
patpatho
Dec 27, 2006 04:50 PM
sir_nasty
Mar 10, 2006 01:49 PM
