Plz help to locate the O2 sensor Bank 1 sensor 1
Old Mar 10, 2013 | 09:03 PM
choi's Avatar
Default Plz help to locate the O2 sensor Bank 1 sensor 1
Thank you for clicking the thread!!
Want to replace the O2 sensor since got the code P0134 and P2251, having a hard time in locating this baby.
My car is a 2005 accord ex-l coupe, V6 3.0L. So the question is the bank 1 sensor 1 should be upstream front or rear???
I found two O2 sensor under the hood, please help me to identify if either of these sensors are Bank 1 sensor 1.
Thank you so much!!
closer view of 1
closer view of 2
Old Mar 11, 2013 | 02:11 PM
choi's Avatar
please help!
Old Mar 11, 2013 | 02:34 PM
Dr. Drivability's Avatar
closest to the firewall is you bank 1 sensor 1, and they are A/F ratio sensors (air fuel ratio) the sensors after the cats are O2 sensors.
See post #5 in this thread:
https://www.hondaaccordforum.com/for...-sensor-45540/
Looking from the front of the car Bank 1 is the REAR (firewall). Bank 1, sensor 1.
Old Mar 11, 2013 | 04:45 PM
choi's Avatar
Thank you, so it's more like the #2 (the above one) in my first pic?
Old Mar 11, 2013 | 06:51 PM
Yes, exactly.
Old Apr 17, 2014 | 09:12 AM
keshcr8's Avatar
Hello, im having the same issue with the same car/specs. I had code that showed bank 2 sensor 2. So when talking to multiple ppl they informed me by viewing the first pic above that its the one that's circled at the top. But when I installed it im still getting the same code.
Ok, I know some ppl would say faulty sensor but I don't think that's the case. I even had someone tell me to switch out sensor 2 from bank 1 to see if thats the problem.
Also with this car which I thought was odd but I know every car is different is that this o2 sensor was found in the front of the car like bank 1 and not towards the center.
When the o2 sensor was installed is it possible that I switched out the wrong o2 sensor because I don't know how many catalytic converters this car has.
Please help!!
Old Apr 18, 2014 | 08:43 PM
Please post the actual code number.
But if it's really bank-2 sensor-2, then it would be down underneath. The sensors you can see from the top are sensor-1 for each bank.
snoopy4369
Feb 27, 2015 07:30 PM
3dw1n
Jan 14, 2015 01:53 AM
compiler
May 26, 2011 02:42 PM
vitalithestudent
Jan 14, 2010 02:42 PM
haoleflip
Aug 4, 2009 06:14 PM
