Popping out of 5th gear
Old Mar 19, 2012 | 05:33 PM
crispin's Avatar
Default Popping out of 5th gear
depressed...
Just took the car for a mini vacation to Gatlinburg, TN after swapping in the 5 speed to replace the blown auto that I had.
It is about 160 miles away. I got there no problem.
On the way home the trans started popping out of 5th gear. I got out and checked the linkage and everything looked just fine.
I had the hold the shifter up in 5th gear in order to drive home.
What I found is that when i accelerate the shifter pulls back and wants to pop out of gear. When I let off the gas the shifter goes forward.
I checked all the motor mounts when I did the swap. I replaced the front motor mount as it was tore but the other 3 were in good shape.
I read somewhere (after searching) about the "shifter bushings" possibly being the problem.
I also know that there is an adjustment on the shifter cables.
Please what do you think I need to do?
My girlfriend needs to dive this car to work on Wend 60 miles.
What do I need to do?
Thank you for your help in advance.
Old Mar 19, 2012 | 07:51 PM
g22cd5's Avatar
Supper Moderator
what trans F or H series? h22 trans tend to have this issue...
Your shift forks look good?
Old Mar 20, 2012 | 06:16 AM
crispin's Avatar
I have an F - Series Transmission.
Shift Forks, are those located inside the transmission or are those the levers that the cables attach to?
I researched shifter bushings and I do not think that is the problem at all.
What bothers me a lot is I had over 600 miles on the car since the swap and everything worked perfectly.
Clearly the shifter is moving under acceleration or deceleration while in 5th gear. I tried it in 3rd gear and the shifter does not move around.
Do you think I have an external problem such as bad motor mount or bad cable routing?
Or do you think I have (a much worse) internal problem?
My other truck just blew its motor so the Honda is the one and only car we have to use.
I really need to fix this problem today.
Old Mar 20, 2012 | 07:07 AM
crispin's Avatar
I have been researching a ton and found quite a few mentions of this problem on a different board.
The #1 reason for popping out of 5th gear is low trans fluid.
I did fill the trans while the car was on jack stands and I think I have it too low.
I am going to check it right now and it would be great if that solves the problem.
Old Mar 20, 2012 | 07:37 AM
I hope it is something simple, because you did a lot of work on the swap.
I don't know if you can look at the shift fork to see if the shift cable is pulling back on it to pop it out of gear.
Old Mar 20, 2012 | 08:18 AM
crispin's Avatar
PROBLEM SOLVED!
It was TOO low on fluid.
I think it was a combination of I did not fill it up all the way (due to the front being on jack stands) and the slow leak from the passenger side axle seal.
I only had a quart of oil here and it took the whole thing so i am going to go to the store and get more and top it off.
I sure hope I did not do any real damage to the transmission by running it low on oil.
I just came back from a short test run and it shifted great and made no type of noise at all.
tkd4ever
Jan 25, 2014 05:58 PM
vral81
Mar 6, 2012 01:28 PM
mishakol129
Nov 28, 2011 05:51 AM
offroadTRD
Jul 3, 2009 06:38 AM
88accord
Nov 10, 2007 09:01 AM
