power aerial
Hi I have a T reg, accord. I am in the uk, the power aerial would not raise so I purchased a replacement and fitted it, however this one doesn't raise either, when I plug in the connector I hear a click, so I assume I have power to the unit, can anybody help please
Likely a defective unit. You can check for power to the antenna drive when radio is first turned on. It should always be present. Circuit opens at power antenna relay when antenna is fully extended.
BTW, what is "T-reg Accord"?
