Sponsored by:
Sponsored by:
Power Lock inop- Driver's Side
Old 03-29-2008, 12:16 PM
MALSR's Avatar
Default Power Lock inop- Driver's Side
Got a power lock (on driver's side only) that won't respond...I have to use it manually to get it to work while the other locks go up and down fine. I think it might be the actuator. Anyone else seen this too?
4dr accord lx 92'
Old 03-29-2008, 12:37 PM
hondadude's Avatar
Default RE: Power Lock inop- Driver's Side
Yes I've seen drivers side lock actuators go bad, ahundred times.
Old 03-31-2008, 09:00 PM
MALSR's Avatar
So I'll assume its the actuator then if that's the consensus. How hard is it to fix? The extent of my mechanical experience is basic stuff like oil changes, valve adjustments, etc.
Old 04-01-2008, 12:58 PM
lightshow's Avatar
its not too hard. small hands would be the best tool to have for the job. handle comes off first. phillips screw in the middle. push forward and pull out. two metal rods now hold it on. be careful with the clips they break. now there is a phillips in the little bottle cap holder on the arm rest. take that out. now just pry the door cover off starting bottom first.
Old 04-05-2008, 11:30 AM
MALSR's Avatar
Thanks guys; I'll give it a try
Old 04-05-2008, 03:04 PM
accord1998
I just replaced my right rear actuator. The part was $43.00. But.....it fixed it! Lightshows instructions are dead on.
jza240sx
04-30-2013 04:14 PM
beberle
12-11-2010 12:37 PM
iimzii85
11-01-2010 01:16 PM
Bobertsr
06-05-2009 03:58 PM
Raptors
09-15-2008 09:43 AM
Quick Reply: Power Lock inop- Driver's Side
