Power Door Locks Inop After Battery Change
Old Jun 5, 2009 | 09:41 AM
Bobertsr
Default Power Door Locks Inop After Battery Change
98 Accord LX with PDL that worked fine before I touched the battery...I changed the battery, leaving it disconnected for about an hour while I cleaned the cable terminals. When I hooked everything back up all was well except for the Power Door Locks which are now inop, no sound, no clicking, no nothing from any door switch. The individual locks work freely when manually raised or lowered. Is there a reset or some other procedure that I must go through to get these locks back in action? Thanks!
Old Jun 5, 2009 | 10:23 AM
00AccordLX5spd's Avatar
Registered User
Hmm...haven't heard this one before. Have you checked the fuses?
Old Jun 5, 2009 | 10:51 AM
Bobertsr
Fuses OK.
Old Jun 5, 2009 | 01:40 PM
Bobertsr
Found It!! Per Honda Service Bulletin 99-022..."Right Side Windows and Door Locks Do Not Work" after battery power to the multiplex control unit has been interrupted.
Corrective action is to perform "multiplex control unit wake-up procedure".
Procedure:
1. Turn the ignition switch OFF.
2. Turn the windshield wiper intermittent time ring to the middle position.
3. Turn the ignition switch ON.
That should do it. If not, it's broke!
Old Jun 5, 2009 | 03:58 PM
Registered User
^^ I forgot all about that! DUHH!! I'm an idiot
InYourDreams
Jul 12, 2013 07:31 AM
beberle
Dec 11, 2010 12:37 PM
Antarctica
Oct 5, 2010 08:33 PM
MALSR
Apr 5, 2008 03:04 PM
dphan2k1
Jul 12, 2006 01:20 AM
