power loss issues
Old Apr 11, 2012 | 04:44 PM
jroxz44's Avatar
Almost A Senior Member
Default power loss issues
This problem has been going on for a while.
after long drives a notice a significant power loss. When i park and rev the motor i hear a slight whistle almost like a vaccume.
It doesnt do it cold only after running it for a long time then get the whistle/vaccume sound.
Ive cleaner the egr ports,replaced egr valve, cat converter, plugs wires and alot of other new parts. Could the IACV need cleaned? Or im thinking fuel filter maby..... im completly lost im going crazy trying to figure this out its really annoying i could really use some help. Has anyone else has this type of problem. Also the idleing drops really low for a little when i put it into drive when ive been running it a long time. Thanks guy hopefully you guys can help. Thanks
Old Apr 12, 2012 | 08:43 PM
Well, cleaning the IACV, adjusting the FITV and the fuel filter are "almost" maint items so I can't hurt anything.
Have you checked for stored codes?
Have you checked for vac leaks?
Old Apr 13, 2012 | 12:53 AM
Tyler Joyce's Avatar
Warmed up=expanding head gasket=less compression=power loss=vacuum leak=whistling sound? Maybe? Never heard a head gasket make a whistling sound. Just grab a couple cans of intake cleaner. Spray all over your engine in pretty much every crease you can find especially around the intake with it running. If it bogs down or dies then you found the spot where its leaking.
tstan
May 23, 2007 04:06 AM
mastar91169
May 10, 2007 01:24 PM
ctstar2000
Mar 27, 2007 08:10 PM
Dano
Oct 9, 2006 03:21 AM
