Power Outlets Stopped Working
Old Aug 28, 2017 | 05:15 PM
OneLuckyGuy's Avatar
From: SD, MN, WI, NM and travel to other southern states in the Winter.
Question Power Outlets Stopped Working
2003 Accord both power outlets stopped working. I checked the fuse and it was blown and I replaced it. Both power outlets still did not work. I tried another fuse and they still did not work.
Old Aug 28, 2017 | 09:05 PM
You need to check both under-dash Fuse No. 9 (15A) and Fuse No. 32 (7.5A).
Power (+) via Fuse No. 32 and the separate ground (-) source are used to energize coil in the accessory power outlet relay, which allows power (+) via Fuse No. 9 through the relay to the respective accessory outlets.
Old Aug 29, 2017 | 01:35 PM
Thank you redbull-1
I checked 32 and it was good and even put a new fuse in and that didn't help.
Old Aug 29, 2017 | 10:18 PM
Do you keep blowing fuses?
Old Aug 30, 2017 | 10:57 AM
dgp1961's Avatar
Almost A Senior Member
Wife lost power in one outlet, replaced the fuse worked ever since...
Old Aug 30, 2017 | 09:21 PM
I replaced the fuse # 9 15 amp fuse once afetr it had blown. That didnot solve the problem. I checked the 7.5 amp #32 fuse and it was good. I even put a new fuse in and that didn't help.
Old Sep 2, 2017 | 05:45 AM
About the only thing left is the relay or a wire issue.
gog222
Jun 21, 2011 08:30 PM
WHATABURGER
Aug 28, 2008 02:32 PM
c33pays
Apr 24, 2007 11:24 PM
DrBones
Oct 13, 2006 07:05 PM
aceracer__
Jul 19, 2006 04:04 AM
