Power Mirrors stopped working
Old Oct 13, 2006 | 06:43 PM
DrBones
Default Power Mirrors stopped working
Hello all,
I have a 2001 Accord LX Sedan Manual Transmission 113K miles. Recently the power mirrors stopped working. I pulled the owner's manual and found the fuse location: Driver's side #4. I pulled the old fuse, but it did not appear to be "broken". I replaced it anyway with a new 7.5a fuse (per owner's manual). Still, the mirrors are not working.
At little bit of additional information: Last June I installed a hard wired FM modulator which I wired thru the power mirror circuit. I've since removed the FM modulator after purchasing a Hon98 Aux adapter. The mirrors worked after I removed the added circuit.
My question(s): Where else should I look? Can the switch go bad on door?
Thanks for all your help!
Dr.Bones
Old Oct 13, 2006 | 07:05 PM
sir_nasty's Avatar
Default RE: Power Mirrors stopped working
the switchs can go bad yes, you can just pop the switch out I believe and then try to jumper accross the different connectors to see if that's the problem, I'd also check the wires where you removed that FM modulator to make sure there's not an inline fuse and that the wires are still together securely...
Antarctica
Oct 5, 2010 08:33 PM
jmtdaddy
Oct 19, 2009 09:41 AM
jmalek
Feb 24, 2009 11:45 AM
jjyynnxx
Oct 12, 2006 09:55 PM
aceracer__
Jul 19, 2006 04:04 AM
